Each
‘CATS’ Training Course is split
into Modules. All modules have a one page specification that lists all
critical content in summary form. This is known as a . . .
‘ModSpec’:
Used in two ways:
Auditors
use it as the key evidence document.
Training
developers use it as a blueprint specification for building a ‘Trainer’s
Guide’ and all supporting materials. These are then located in one
container known as a . . .
‘Training
Pod’:
This
holds all the training support materials.
Trainers
use the Trainer’s Guide & supporting materials contained in
the Training Pods to deliver their courses.
‘CATS’
What
are the benefits of ‘CATS’ training?
All
your training will be constructed to the same rigorous standards.
All
your trainers and developers will be using the same materials. The risk
of uncontrolled training output is greatly reduced or totally eliminated.
Training
materials can be easily and cost-effectively created, maintained and updated
as required.
You
will be able to produce fully documented evidence of your entire training
output quickly, easily and with the confidence of knowing exactly what
you have and where it is!
